Dave Rigotti 3Ch proportional retro-fit
drigotti
Post by drigotti » 29 Nov 2018, 01:14
I'm done with the conversion of a 3ch Thunder Tiger radio. All is well. I did change the pulse width to 400us BUT that is all I did. Winter has set in so I can wait a while for Phil to update the sketch for other goodies...
Thanks to all for the help!
Dave Rigotti
Re: Dave Rigotti 3Ch proportional retro-fit
Post by Phil_G » 29 Nov 2018, 09:22
drigotti wrote:
29 Nov 2018, 01:14
Hi Dave, you also need to compensate by taking 100uS off every channel, otherwise your neutrals will be out. Its all caused by Spektrum's non-standard PPM timing, one of the many reasons I'm not a Spektrum fan! When I get a mo I'll separate out the PPM so you can easily set it how you like, but unforch as it stands on the 7ch its not just a case of extending the pulse to 400uS. As you know from your previous project, with the Reeduino you can!
drigotti
Post by drigotti » 30 Nov 2018, 02:51
Phil,
That would be good for me.
Thanks
Dave Rigotti
drigotti
Post by drigotti » 06 Mar 2019, 17:55
Phil,
Any update to the sketch as mentioned below?
Thanks
Dave Rigotti
drigotti
Post by drigotti » 28 May 2019, 15:42
Phil,
Last we "talked" you were working on an update to the 7ch proportional sketch which included some neat new features. Flying season is here and would like to "update" my sketch.
Any news you can share?
The timing I have is not ideal for the Spektrum as discussed below.
Dave Rigotti
drigotti
Post by drigotti » 09 Jul 2019, 14:06
Can anyone help me with the timing change as explained by Phil below? 100us off every channel? Where and how do I do this?
Thanks for the help!
Dave Rigotti
Post by Phil_G » 09 Jul 2019, 15:02
Where "neutralPulse" is defined, and initialized to 1200, just change the 1200 to 1100 Dave
static int ppm = 0, ppmPulse = 300, neutralPulse = 1200;
change to
static int ppm = 0, ppmPulse = 300, neutralPulse = 1100;
Presumably you changed the ppmPulse = 300 statement to 400?
drigotti
Post by drigotti » 10 Jul 2019, 10:39
Thanks Phil.
Yes I changed the 300 to 400. That is the only change I made,
How about these values to 1100 also?
float ch0val, chtemp, channel[]={1200,1200,1200,1200,1200,1200,1200,1200}; // last is sync
Dave Rigotti
Post by Phil_G » 10 Jul 2019, 12:40
You can change those too if you prefer Dave but they will have no effect.
The values are just a reminder for me ;)
Who is online
