Here's my Ace MicroPro 8000 single stick:
It dates from 1995 and is a computer system that even had a computer interface for downloading and uploading to a PC (running DOS!) back then! This one uses a FrSky "hack" module, and you've seen it at Ponte. Here's the "standard" version (on 459 MHz, naturally!)
The twin stick version features "crossed trims", so the trims for the RH stick are on the LH side, and vice versa. Both also have an auto-trim button, which re-centers the sticks to wherever you are holding them when pressed - and at a programmable slew rate as well!
When I was building sets with mechanical trims, I always turned the sticks around so that the trims were nearest the edge of the case:
Much better ergonomically!
More single sticks:
And a Talisman UHF that I must have set up when it was made, but had forgotten all about!
Don't ask me what all the levers do! It was obviously built to special order, and has some very strange mixers built in! Luckily, they can all be turned off!
Finally, my Digimite-8:
Still working! And yes, the trims are odd, as they move the stick centre, but not the end points! If it had moved the end points, the servos would have stalled when the linear rack outputs hit the end! Servo reversing was achieved by simply removing the servo, turning it 180 degrees and putting it back! They were completely symmetrical!
