Hi all
Just received my full size copy of the Wizard of Oz plan, what a wonderful aircraft. Has all the attributes of a good day out. Sturdy construction for rough field work , bigger than expected. Am looking forward to starting work on this one.
Clive
Wizard of Oz
Re: Wizard of Oz
Clive
I know others of this parish like to re-scale various designs of yesteryear. Will you be building full size? More importantly will you be staying with all that lovely (until you try to cover it) under-camber?
Just asking as I have looked long and hard at the W-of-Oz and wondered whether a 36" version might make a nice model?
Regards
Gordon
Regards
Gordon
Re: Wizard of Oz
My thinking as well, its quite a piece of furniture. Love the under camber, reminds me of KK Senator, Im sure that's what gives that little model its wonderful glide.
Clive
Clive
Re: Wizard of Oz
Hi Clive,
Thinking of building one how did yours work out?
Best
Nick
Best
Nick
Re: Wizard of Oz
(originally posted this under wrong thread...)
I've been serial building Wizard(s) of Oz as it was my first slope soared on super regen futaba
Made a 48 inch version and two smaller sizes - tried to take some video but failed
some pictures here - again you need to be an enthusiast ...
https://av8planes.weebly.com/wizard-of-oz.html
I've made wings out of 6mm depron ribs + 3 x carbon fibre arrows + 2mm correx - right hand side is covered with doculam and left hand side in H king film to see the difference (doculam slightly lighter)
Fuselage in 6mm depron + some ply under nose , tailplane is same as wings
Some advantage in having correx on undersurface if you fly over stones
Re: Wizard of Oz
My new Wizard
Just finished my third Wizard Of Oz (WOO). Sorry about the indoor photo but once again the wind is howling outside and even the Woo's wings would barely take the stress if I ventured into the storm.
It is built more or less as per the plan and covered in Solartex. I haven't flown it yet (not surprisingly). The canopy is solid balsa block which was intended to be the plug for a clear canopy but as I needed weight in the nose I just used that instead. The front end feels very substantial as a result.
I will probably edit this as I think of more to say.
Think I may call it the "NOO WOO"!
Re: Wizard of Oz
'Lovely job (as usual) Glyn! What happened to the other two?
Re: Wizard of Oz
I think we lost Glyn's 'Wasserkuppe' thread with 'Reunited' but I remember photos of the WOO going well there...
Re: Wizard of Oz
Hi Paul and Phil
My first Wizard I built when I was about 14 or so, I think I crashed it trying to fly off a pit spoil heap up in’t north a long time ago!
The second eventually had to be put down after being lost on the north Yorks Moors for a couple of weeks and getting very wet and warped. Ron managed to locate it and sent it back to me via the greatest retrieval sagas known to man. Well nearly!
I hope to revive the “Flying in Famous Places” with the new Woo.
Below is the 2nd Woo flying at the Wasserkuppe.. great holiday!
Re: Wizard of Oz
Great shot of your WoO. Looks a wonderful location
