Page 2 of 2
Re: Onboard Motor Timer
Posted: 17 May 2018, 06:19
by tiptipflyer
Great work Carl, I will build one for sure. It may come in handy some time. Thanks for posting.
Posted: 10 Aug 2018, 12:59
by Carl
After yesterday's flights with my Mattel Pulstar I'm going to have the warning that the motor is about to cut a little earlier. Currently it does a momentary cut each second for the last 5 seconds, but I'll do this 15 seconds from the end instead. So a momentary cut each second for 5 seconds as before but then the final 10 seconds normal power. It'll give more time to get into a position for better landings.
Posted: 09 Nov 2018, 00:42
Hi Carl,
Belated congratulations on this neat little project
Shall definitely build one
Posted: 09 Nov 2018, 08:22
by Carl
Thanks Wayne, I just need to upload the latest sketch where you can set when the motor momentarily cuts 5 times before the end of the timed motor run. I'll do that later.
Posted: 12 Nov 2018, 08:22
by Carl
I've uploaded the updated sketch at the end of the first post:
15 seconds before the motor cuts at the end of it's run, there are 5 momentary cuts to the motor to indicate the motor run is soon to end (this time period can be customized in the code)
