Posted: 24 Apr 2018, 14:38
Don't forget it's only just under 6 weeks to Ponty.
The Mystery model details will be released on Tuesday 1st May and a part kit will be made available for an even quicker build.
To get things started you will need:-
* A Cox 020 sized motor (preferably a TD but a Pee Wee will do) or similar sized glow or diesel. Beam mounting will require a slight mod to the design.
* For electric something like an 1811 - 2900kv on 2 - 3s 300 - 450 mAh . I used a 3x3x4 bladed prop on mine
* One 5 - 9g servo
This model can easily be built in a day taking it at a very leisurely pace.
It will be featured in the next RCM&E available in a couple of weeks and includes the plan but I will give a link to the plan on Tuesday here.
No other rules; you have complete flexibility how you make yours as long as it is built in the spirit of the original.. You can even uses Depron if you want (but then you'll have to live with the guilt of not using balsa )
* One 5 - 9g servo
