Wanted V8 diy module
Posted: 01 Feb 2019, 17:11
by RON
Does anyone have a New V8 DIY RF module they would like to sell me please.
Re: Wanted V8 diy module
Posted: 01 Feb 2019, 18:19
Sorry Ron, you had my last one a while back.
But if you take a DHT module, de-solder the telemetry connector and re heat-shrink the pcb, it is within 1mm of the size of the V8 in all dimensions. Is your matchbox that tight for space?! I would normally offer to de-solder the connector for people as most are nervous of doing it, but I know your soldering skills are better than mine, so you'd find it really quite easy.
And the new V8 and D8 FrSky Rx auto-senses the protocol of the DHT and will work with either type, so you don't need the three position toggle switch, saving a bit more space.
But I'll ask around my friends to see if any has a transmitter with a V8 in it, that they'd be happy for me to swap over with a DHT.
Posted: 01 Feb 2019, 21:39
by RON
Thanks Mike
I prefer the V8. It mounts so much neater.
Posted: 02 Feb 2019, 08:14
Hi Ron
With the telemetry connector removed, the 3 position toggle switch wiring removed and then re heat-shrinked, a DHT looks the same as a V8-HT. If it wasn't for the label you'd be hard pressed to tell them apart without a close look. In fact with our label making ability (thanks for the tutorial Ron!), you could print a V8 label and nobody would know the difference.
Honestly it is just as easy to mount as a V8, because you make the DHT the same as a V8. I'll modify a DHT this weekend and post it to you next week (we still have 3 inches of snow laying and I won't be going into town today). Anywhere a V8 will fit the DHT will fit just as nicely. And you have the advantage of it working with V8 and D8 Rx.
Posted: 02 Feb 2019, 08:21
by RON
Thanks for that Mike,
All the v8s I've seen are quite a bit smaller than the D series versions, plus they are double sided where the V8s are single sided
