Page 4 of 8
Re: Went Flying Today
Posted: 02 Aug 2018, 19:27
by Carl
Posted: 03 Aug 2018, 16:05
Hey Carl, congratulations on the steady progress - perseverance does indeed pay off
The day we stop learning is the day we stop breathing, and I've still got a lot to learn
Posted: 03 Aug 2018, 19:19
by Carl
Thanks Wayne. It was easier learning to drive and ride a motorcycle, but I was only 17
Posted: 05 Aug 2018, 11:45
by Sundancer
In common with most of Europe, in S-W France we have been sizzling in a heat wave all week - not as bad as Spain but still afternoon temperatures up in the mid to high thirties which, as far as I am concerned, precludes any activity except cowering in the house with shutters closed and fans on. The last couple of hours before dark are better, but by that time I am too fagged out by the heat to raise the energy to go flying. So I tried a different approach this (Sunday) morning and was on the 10 minute drive up to the field in Vayres (
https://www.ma-db.com/airfield/10173) by 7 a.m as the sun rose, with a boot full of rudder only and lightweight RET models. It was still blessedly cool, welcome after trying to get to sleep at midnight in 25 degrees, and glassy calm. Enjoyed a couple of flights each with the Metro Gnome
and Frog Witch using the Macgregor S/C Tx
A lengthy soaring flight with
the Tarquin
- T36.jpg (11.71 KiB) Viewed 4843 times
and three with one of my favourites, the George Woolls "La Paloma"
I also had the Rubberdub with me
But it wasn't flown as in a senior moment I had left the all moving tailplane halves in the workshop!
Back home at 9:30 for a bacon sandwich, coffee and pain au raisen. What a nice way to start the day, and wise as now (12:30) it is already up to 29 degrees and climbing.
Posted: 05 Aug 2018, 22:15
by Sundancer
Well, it did get up to 36 degrees by 3 pm, but it was down to bearable levels by 7:30 so I dashed up for another ssession, 2 more flights each with the Metro Gnome and La Paloma and three with the aileron Widgeon. Drove home in the dark happy with 14 flights in the day.
Posted: 06 Aug 2018, 13:06
by RON
Me and our Oliver went flying yesterday. Newcastle to Heathrow
British Airways Airbus A321
Managed to get him a sit in the cockpit.
Posted: 06 Aug 2018, 13:47
by Carl
Sundancer wrote: ↑05 Aug 2018, 11:45
Any chance of seeing the all moving tailplane on the Rubberdub? Heard about them so it would be interesting see this one.
Posted: 06 Aug 2018, 15:54
by Sundancer
I'll do my best Carl, via some photos.
First stage of building:
Second stage:
Halves separated:
And joiners inserted:
Note that the centre section is cut away at the rear actuating rod position to allow movement AFTER it has been assembled to the fuselage. The actuating crank is custom cut from 1/16" GF board. Finished assembly on fuselage:
Showing up and down movement - note MUCH less than this is used in practice:
Finished job:
Hope you can make all that out! If not clear, say so and I will try a written explanation!
Posted: 06 Aug 2018, 18:03
by Carl
That's great a good example of how pictures can explain something really well. Thanks Sundancer. A really neat way to add elevator on a model with a built up tailpalne.
Just one question - are the two halves held in position by friction?
Posted: 07 Aug 2018, 07:11
by Sundancer
Yes Carl, I just bend the wires VERY slightly so that you have to spring them to fit the tail, the friction is then quite sufficient to stop the tail halves moving. Here is the same sort of set-up on my electrified Lulu II soarer, in this case the tailplane had to be raised slightly from the F/F version.
