HK OrangeRx DSM2/X Futaba-style modules on offer
Like B&Q for homebrew radios
Post by Phil_G » 15 May 2019, 12:17
HobbyKing have the OrangeRx DSM2/X Futaba-style modules on offer at £20:
https://hobbyking.com/en_us/orangerx-sw ... tible.html
Its the switchable version which makes it more versatile. Using the DIP switch you can set the RF output power, set the protocol to DSM2, DSMX, Walkera or 'auto', enable/disable channel mapping (eg AETR to TAER), choose the framerate (11ms or 22), resolution (1024 or 2048)...
I'm not a Spekky fan but for only £20 I thought I'd buy one for my stash :D
Re: HK OrangeRx DSM2/X Futaba-style modules on offer
Post by Carl » 15 May 2019, 12:46
Won't you get clobbered with import duty as it's over £15? It's only available from the China warehouse.
STILL LEARNING
jackdaw
Post by jackdaw » 15 May 2019, 13:46
'Fraid so. 20% on £20.54 = £4.108. To which they could charge 20% on the shipping cost and then the GPO will charge you between £8 to £12 to collect it. Or, you could be very lucky and it could slip through.
Colonel Blink
Post by Colonel Blink » 16 May 2019, 07:52
You actually used to be able to specify what percentage of the true value that would be put on the customs label, but that is long gone. However, they do seem to put an arbitrary low value on for the stuff I have bought.
I'm not sure how many orders I have made on the HK Worldwide Warehouse, but it's quite a few and I've only been stung for the VAT/import duty once, just after they got rid of the aforementioned 'percentage of true value' option and were I think marking the true value. They probably stopped that once they saw the average order value plummet! Mind you, I have only bought small packages where the sub £15 value is believable to anyone handling the package - I would think that would be unlikely were you to be silly enough to buy a kit.
jackdaw
Post by jackdaw » 16 May 2019, 08:33
https://www.gov.uk/goods-sent-from-abroad
Work your way through this lot. First mention of the £15 limit on personal imports is on page 2. But, what I put in my previous post is correct. Its' just luck if you get through without paying when you should. Possibly more chance from China/HK of escaping but I've found that anything coming from the USA you get caught.
Post by Phil_G » 10 Jun 2019, 15:32
You were right Allan - £12 import duties to pay making this cheap £20 module an expensive £32 module.
I didnt really need one, I only bought it cos it was cheap.... I dont generally do Spektrum stuff.
Lesson learned. Come back Rob Carpenter all is forgiven :D
jackdaw
Post by jackdaw » 10 Jun 2019, 19:03
No chance of that. If he gets his crystal balls from the same place I do then there is little chance of making money in a contracting market place.
Who is online
