Staveley Badge WANTED
Does anyone have a spare Red silk-screened Staveley aluminium Badge to help with the restoration of a transmitter?
Thanks in advance!
Stuart
Thanks in advance!
Stuart
Re: Staveley Badge WANTED
I've got a spare Futaba label if that would help?!
If nobody has a spare label, I can Photoshop a copy of my Staveley Analog when I get home.
Thanks Mike!
Shaun has been in touch and might have a spare replica badge
Or is that re-birthing in the Mackay chop-shop
Well, hopefully, a bit of a result, inasmuch, that my local print shop has said they can hot print the Staveley logo onto thin aluminium!!
It will take about a week, but hopefully will be able to share the results with you in the coming days and if it works as well as the samples I have seen, we might well have found a modern low-volume method of replicating the aluminium badges seen on so many radios of the 60's, 70's & 80's!!
You will be impressed, it's an amazing technique. I have been using it a few times not least reproducing the badge on my Kraft Signature to get dates and name correct as it was retrofitted to 2,4 GHz, remapped as it was brought from mode I to mode II
Looking forward to see the outcome.
I should just have done the logo and had engraved name and date to give more life to itLooking forward to see the outcome.
