Identify transposed A4 & A5 on ebay boards
List all your sketches here
Post by Phil_G » 17 Mar 2018, 16:17
Deliberately simple, throwaway sketch to prove A4 and A5 transposition or not.
Flashes A4 four times, and A5 five times, with the D13 led slowly flashing as confirmation that something is happening.
// Identify transposed A4 & A5 connections, flash A4 4x and A5 5x continuously.
 void setup() {
   pinMode(A4, OUTPUT);
   pinMode(A5, OUTPUT);
   pinMode(13, OUTPUT);
 void loop() {
   digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
   digitalWrite(A4, HIGH);   // turn the LED on (HIGH is the voltage level)
   delay(200);               // wait for a second
   digitalWrite(A4, LOW);    // turn the LED off by making the voltage LOW
   digitalWrite(13, LOW);   // turn the LED on (HIGH is the voltage level)
   digitalWrite(A5, HIGH);   // turn the LED on (HIGH is the voltage level)
   digitalWrite(A5, LOW);    // turn the LED off by making the voltage LOW
_AL_
Re: Identify transposed A4 & A5 on ebay boards
Post by _AL_ » 18 Mar 2018, 00:27
Brilliant.
Al
