Diesel engine STL
AlexC
Diesel engine STL
Post by AlexC »
I have been searching for a Diesel engine STL file to print, the only one I have managed to find was a cutaway version.
Anyone know of any other designs?
Re: Diesel engine STL
Hi Alex,
I made several diesel engine cylinder heads for 3D print. Taifun Hobby, Hurrikan,Tornado and Mills.
They are printed in two halfes, then glued together, painted in the appropriate color and make real nice dummy engines.
The compression screw is made of a M3 screw with a piece of wire soldered on top.
In the zip. file you find both stl. files and OPENscad files.
Mills.zip
(119.69 KiB) Downloaded 438 times
Taifun.zip
(224.67 KiB) Downloaded 429 times
I hope, that is what you need.
WernerL
Post by WernerL »
Wow, they are sweet! Thanks for sharing!
greetings from Singapore, Werner
Love your work Frank!!
Thanks for sharing mate ;)
AlexC
Post by AlexC »
Thanks Frank,
I will print them up.
Alex.
AlexC
Post by AlexC »
John IIsley, One of the lads on another Facebook page kindly uploaded this Mills .75 STL file he designed.
55mm mills.75.stl
(959.26 KiB) Downloaded 409 times
AlexC
Post by AlexC »
I have attached another 2 files. These should cover a motor of 18mm diameter as in the photo.
tom 2.stl
(1.3 MiB) Downloaded 390 times
TOM mills.stl
(1.21 MiB) Downloaded 411 times
