Don't ask me why I try to fix this stuff, especially old reed sets from the UK, but I get what I deserve by trying....a BIG headache!
I have a REMCON 12 receiver with a dead audio stage, very low (.5V peak to peak ) audio signal and so I need a schematic to figure out the circuit, and what types of transistors are used, and the electrolytic cap values.
I see it has Jap transistors, which are very hard to source here, as they were never popular and nobody ever carried a good stock of them at the retail level. Hopefully I can use a general purpose silicon transistor to substitute if the original is bad, but I need a schematic 1st. Of course now I'm really getting hopeful and would like a component layout, but that is probably a pipe dream!
Any help is appreciated lads,
thanks in advance,
Jay
Remcon 12 Rx schematic needed
Re: Remcon 12 Rx schematic needed
I poked around and found an open winding on the audio transformer. How to find one of those?
M48 on the Archive page Jay
Thanks Phil, I'll open it up and get back to work fixing the REMCON 12, will post pictures,
Jay
Jay
Transformer T1, 5:1 ratio, has an open primary, and the winds are not broken at the terminals, so it must be internal. I'll have to try and find a replacement, so if anybody has one I'm interested.
Thanks again,
Jay
Thanks again,
Jay
Remcon fixed!
I decided to abandon the transformer, so it was removed. In it's place I used a 10K resistor where the primary winding was, that added a collector load to the detector/audio amp. Then I connected a .47uF cap from the collector of the detector/amp to the base of the reed bank driver transistor at the point where the transformer secondary used to connect. Viola, it works really well and now, I have all four servos that came with it working. It started to get a little weird after repeated testing and that was the airborne battery getting low, so I put it on charge.
My inspiration came from looking at an Orbit 10-12 channel reed receiver; they do not use an audio transformer to couple the 1st audio amp to the driver, instead they use a 1uF for DC coupling of the stages. I hope Dunham and Mathes (RIP) don't sue me for copying their design
I'm sure you have reached the limits for The statutes of limitations!
Hi J Mendoza, That is very clever to iliminate the 5:1 ratio tx. I cant find the exact copy of the old d1001 Ardente or Henries radio anywhere. Thanks mate respect!
