I can recommend this one:
https://www.ebay.com.au/itm/110-220V-20 ... :rk:6:pf:0
I've had it almost a year now, cheap as chips, heats up quickly, trigger feed works well, I use it regularly and so far it hasn't missed a beat. 'Tis much better than my original "clunker" (which still works after 25+ years), but holding the handle while directing the nozzle while feeding the glue stick with your thumb while trying not to burn yourself challenges both my arthritis and my patience! The new smaller version is a 'lil ripper!!
An issue with an OrangeRx DIY module
Re: An issue with an OrangeRx DIY module
I can figure out the power but where's the ppm connection for this module,Wagga_Wayne wrote: ↑10 Jan 2019, 12:18 I can recommend this one:
We
Don’t you know nowt Shaun, it’s BluetoothShaun wrote: ↑10 Jan 2019, 14:53I can figure out the power but where's the ppm connection for thisWagga_Wayne wrote: ↑10 Jan 2019, 12:18 I can recommend this one:
We
