Simple PWM display
Arduino projects on the go
Re: Simple PWM display
Post by RON » 18 Aug 2019, 15:14
Phil_G wrote:
18 Aug 2019, 15:08
Yes if you can find one, all four display pins line up with the "Mini" A4 A5 + - all in a row, so a 4-pin header could be used to join the two:
You should have one kicking about Phil, I remember giving you one years ago :D , if you haven’t used it if course.
If you would like to contribute a small amount toward the upkeep of this valuable forum then please click the Donations link at the top of the page, just below the mode zero logo. All donations are kept anonymous. Thankyou
Post by RON » 18 Aug 2019, 15:31
They are perfect for SC Transmitter meters, so small, they mount on the back of a 0.96 oled and don't take any room up
Post by tiptipflyer » 19 Aug 2019, 18:10
Thanks Phil for this little project. It works great.
Mine did not need any pullup-resistors.
Post by RON » 25 Aug 2019, 19:12
here is a slight variation to Phil's simple tester,
using a128x64 oled, I've incorporated a rx battery level meter too.
Notice this Oled is the split screen yellow/blue version which works nicely on this one
