PhilG GG encoder question
Waggly tails
jmendoza
Post by jmendoza »
Phil,
I'm planning on setting up 2 of Tobe's actuators in a dual set-up for high pulse rate.
I would like to use my converted Controlaire transmitter which is loaded with your GG encoder sketch, but I will need a 4th channel ) to use for controlling the pulse rate of both the actuators.
Is there any way you could add one, or better yet two extra channels to the GG encoder sketch? If possible, I would like to use a couple of the analog inputs with 5K pots to control the actuator rates.
Of course, I could use my Spektrum DX-6i, but that would not be half as fun as using my Controlaire GG set with your encoder, it is so much more correct.
Thanks Phil,
Jay
jmendoza
Re: PhilG GG encoder question
Post by jmendoza »
Phil_G wrote: 27 Mar 2020, 18:51 See your email Jay
Thanks Phil
Jay ;) :D :)
JohnH
Post by JohnH »
Hi Phil,
I was also thinking of doing the same thing that Jay wanted to do. In fact I have a great Rand Dual-Pak that Jay restored for me. Could you send me the same email or PM as you sent to Jay?
Thank you.
John Haffner
John H.
