Sanwa help please.
Posted: 20 Oct 2021, 22:42
Hi,
I'm about to convert this set and would like to make it 6 channel like the very first propo set I owned back in the 70's.
Has anybody got an auxiliary slider, u/c switch and lockable power switch going spare please from a junker set.
I believe the next gen Excellence used the same slider and u/c switch but this set had a slider for the power.
Re: Sanwa help please.
Posted: 21 Oct 2021, 09:13
Where have I seen that transmitter before?!
If you can wait until the weekend, I probably have a Sanwa 6-channel set with an auxiliary and switch, but the switches all seem to have a bit of corrosion as the Sanwa battery is a pain to remove, so usually get left in long term and then the switch is the first thing to get corroded. If you prefer, you can still buy similar switches from Digikey, Mouser and probably RS and Farnell. The part you need is:
https://www.digikey.co.uk/en/products/d ... -C/2105189
You have to remove the plastic shroud on the original switch and unscrew the cap off the new and swap them over. Easier said than done, but possible.
Posted: 21 Oct 2021, 09:45
by Spike S
Hi Shaun
I converted one of those back in 2018 (?) and it has had continuous use for S/C button and sticks since then. Case is quite tight but 'doable'. I thought I had generated a thread on that but can't find it. Lots more inside phots if you want.
Rates trimmers in the top opening so no extra case holes needed. Bind LED fed into the bottom of the transparent meter housing
Is this what you are looking for ?
The display had been removed (loose inside) but otherwise the delightfully robust metal case is untouched. Sticks are really smooth and it would make a great conversion in preference to being a donor 'Christmas tree'.
Too many other projects ! I would have brought it and another bunch of converter candidates to Ponty for swaps had I been able to travel. Yours if you want it.
Posted: 21 Oct 2021, 11:31
by _AL_
Mine.....
Posted: 21 Oct 2021, 12:52
Thanks for your replies gents; appreciated.
Spike, l believe I have one of the sets you've offered in good original nick in the museum collection. Let me have a look and see if the aux pot etc will fit. I'll get in touch but I'll wait until Mike gets back re spares from the same model set as that would be a direct fit.
Cheers all,
Rgds,
Posted: 21 Oct 2021, 14:19
by PaulJ
Spike, Where did that Black Sanwa come from? I have been looking for one of those! I WON one in an RCM&E competition many years ago...... I can't remember what happened to it but I have never seen another. It wasn't clear from your posting if you plan to convert it but if not, please don't dismantle it for spares, I would like to buy it from you...... pm sent.
Posted: 21 Oct 2021, 17:19
by Spike S
PM replied to you and Shaun
