Page 3 of 3
Posted: 03 Aug 2019, 04:05
by ozrs
What amount of throw is required - (say in degrees)?
Posted: 03 Aug 2019, 10:13
Dunno but if you copy the geometry from the pics Rich, mine does twinkle rolls and its really very responsive which is how I like my gliders, needs very little stick movement in normal flight. Shaun has flown mine, he'll confirm its really snappy
30mm and 65mm for me:
Posted: 03 Aug 2019, 10:29
With hindsight, I put the 'spar' (pivot axle) too far back on my Lidl wingeron, and the place where the control rod to the servo entered the wing a little too far forward. I test flew it and it was controllable but even with the transmitter throws maxed out it was not very responsive. Rather than remake the wing pivots, I just fabricated some extra-long servo arms by cutting one long arm off a servo and fastening it on to the end of the other long arm. I now get slightly more wing travel than is shown in Phil's video.
Posted: 03 Aug 2019, 12:10
Mine are nearer 35mm and 100mm
You can see the original position where the control rod went in near the wing leading edge, and the cutout in the wing stub to give clearance. With the longer servo arms, I also made some new links that fit into the wing further back, so those cutouts are no longer used - the clearance cutout is now in the wing panel rather than the wing stub.
Posted: 03 Aug 2019, 17:27
by ozrs
Thanks for the info guys - that's more than I need to get started - will post some pics when done.
Posted: 24 Aug 2019, 16:07
by Spike S
Spotted at our patch today. LIDL Twin. 2x 100W motors. Goes like stink ! Conventional Ailerons and Elevator. No rudder but differential throttle instead (subject to ongoing experimentation)
Posted: 25 Aug 2019, 05:42
Spike S wrote: ↑24 Aug 2019, 16:07
A man after my own heart, BUT, Damn - he beat me to it
I'd envisaged my "variant" to have a T-tail, like the full size
Bronco. Ah well, maybe one day
Posted: 25 Jun 2022, 07:56
Aussie folks can get the Lidl glider (if its not out of the same Chinese factory I’ll be amazed!!
) from K-Mart for $10
https://www.kmart.com.au/product/big-fo ... -43073931/
Also available in NZ from K-Mart but I don't have link details. Thanks for the "heads up" Barry
I've ordered 4, currently in transit. It'll be good to try some of the conversations you UK types have experimented with. Also, I can do a direct comparison with the Banggood
Cheetah.
