hello,
do you know this timer for E-VCCl, very simple
https://vcc-indoor.monsite-orange.fr/pa ... 0821d.html
best regard
E-VCC simple
Re: E-VCC simple
Hi Franck,
What a coincidence, I have just spent a whole week to develop a similar timer on the basis of a ProMini. My concept is much simpler that the one you present, I am just using a pair of jumpers to choose between 3 different preset run times, and a variable resistance to set the motor speed. Delayed start and slow start/stop is provided. I am using a regular Rx bind plug to set off the sequence.
Yours is much more refined, but at the same time requires a lot to remember when you want to make changes at the field without your PC........
Re: E-VCC simple
it's possible to change parameter at the fiel, see here for technic but in french sheet 9.
https://vcc-indoor.monsite-orange.fr/fi ... 7a8385.pdf
Re: E-VCC simple
You may find further "inspiration" in Carl's efforts along similar(?) lines
viewtopic.php?p=1683#p1683
