DIY-more PCB with 16U2 usb
Thank you very much Phil. Hard to keep track of all the variations. Most recently i came across one with the Atmega16U2 as programmer instead of the CH340G. It seems the 16U2 can be flashed with a different firmware, maybe that can be used in our advantage...
Re: DIY-more PCB with 16U2 usb
Forgot to add the link to my previous post. This board is very similar to the one Stewart posted but it seems to have a different programmer chip:
https://www.ebay.com/itm/Replace-CH340G ... 1438.l2649
Well, I finally got two of these for 2.5 euro each through auctions. I wasn't in a hurry so I tried my luck a couple of times instead of "buy it now". I used Zadig to install the USB-Serial driver and upload the Blink Sketch. The power and onboard green LEDs are so bright, I had to cover them with tape (in a bright room, even)
I will have to read more on the 16U2 chip...
As far as I understand, this library might be useful to turn these dev board into HIDs. I wonder if it's possible to connect the PPM output of our encoders to our laptops and play some Picasim or RC Desktop Pilot.
