Page 19 of 24
Posted: 12 Mar 2021, 18:29
by Tobe
The full "enchilada" 4 ch "MaxiPelle R/C set, NRF24+
Posted: 12 Mar 2021, 19:54
by PaulJ
Fantastic! Hats off to you Tobe...... Well done!
Posted: 12 Mar 2021, 20:21
Posted: 13 Mar 2021, 00:06
Ab Fab!
No wonder your running out of solder mate - better get another container of filament while your at it, 'cause I think your going to be busy
Posted: 15 Mar 2021, 01:14
by iflylilplanes
Love it,
would like to see a full house model flown with this setup and the GG version same model.
Only one issue, the throttle stick is on the wrong side.
Posted: 07 May 2021, 18:17
by Tobe
Here are suitable Rx compatible with Phil's lockdown project.
...not sure if I'm going to print cases or I will be opting for shrink tube
Posted: 19 May 2021, 11:56
by Tobe
There are a few nRF24 Rx and nRF24 Tx pcb's of my design available so for those of you that might be interested please PM. They are at cost plus S&H
They runs straight forward with Phil's nRF24 project and here comes a pic in how to connect your USBASP to the Rx as the Tx has regular ICSP.
My take on 'Model Memories' - they belong in the receiver!
Posted: 03 Jun 2022, 12:58
Further experimentation with the homebrew FHSS set... I've always thought that conventional "model memories" were in the wrong place, why are they in the transmitter where you have to 'select' the right one for a model?
Surely the individual configuration for a model should be in the model, ie in its receiver?
On the back burner I've been wanting to do some small NRF updates, Ponty gave me enough mojo to at least move the mixer and reversing into the receiver. It works exactly the same so you wouldnt know I'd moved it.
It means for example I can fly the Lidl Wing with any of my transmitters without having to go inside to enable the mixer, and that I can use my little black & red Lidl transmitter with the Rudder-elevator Lidl glider or the Lidl Wing - or any combination of my models and transmitters - without changing anything, and with no need to 'select a model memory'. Theres no possibility of launching a model with the wrong configuration selected - the configuration is already in the model!
The video shows two different models, one a flying wing using an elevon mix, and one a simple rudder/elevator model with no mix at all. Reversing has been configured for each individual model and each overall configuration is then stored in its receiver. "Model memories" are redundant!
A small step in a work-in-progress, but at least its a start
Following on from Tobes post above, here is a diagram of Tobe's rx PCB with USBASP programming connections:
Posted: 03 Jun 2022, 16:44
by Pchristy
Excellent idea, Phil! It makes a lot of sense!
Posted: 05 Jun 2022, 12:47
by Flynn
Hi all.. a bit late to this party so please excuse if I'm behind the curve.
The RF-Nanos you are using for this project - are they 328p RF-Nanos or LGT8F328P RF-Nanos?
https://www.aliexpress.com/item/1005003745213152.html
As you can see there is quite a price differential.
Some info on the LGT8F328P
https://sites.google.com/site/ericmklau ... uino-clone
