I missed the calm weather window over the early weekend, and unfortunately since then we've experienced multiple cold fronts & strong winds
. However early this morning the weather was actually better than was forecast, so flying we went
. In addition to the
Senator for it's maiden flights, I took the
Pageboy & the
Fly Dragon, both of which had received minor tweaks so needed (re)test flights.
The
Senator flew delightfully
- to be honest, I'd have been disappointed if it hadn't
. The power level is just right, the motor drawing a paltry 2 amps driving the big slow-revving GWS plastic prop & providing a very realistic climb & heaps of flight duration. I had 3 flights, the only trim change being 2 clicks of left rudder trim. Before the next outing, I'll move the battery aft to shift the CofG back a few mm, which should then make the glide 'perfect'. The higher than anticipated flying weight was of no obvious consequence, and should assist with penetration in a light breeze.
I managed to unknowingly bump the Go Pro out of alignment so most of the video is clouds
grrrrr
, but I did manage some frames with the
Senator included. I'll edit the video & upload it, but in the meantime, here are a few captures from the video.
- Before the maiden flight
My new 1+1 Tx performed perfectly and is an ideal compliment to the
Senator.
A very satisfying F/F conversion
........ Bring on those balmy summer evenings
