Sprengbrook 3 channel propo Tx
Re: Sprengbrook 3 channel propo Tx
Offer accepted, pending inspection of item.
The Sprengbrook/HB 3-channel Rx I already have to hopefully go with the 3-channel HB transmitter
together with the assembly manual
Interestingly, the Rx I have has the servo connectors onboard, the assembly manual show them on flying leads, otherwise the PCB layout and components look identical
And here is the factory built item with the sprengbrook badge attached and a slide switch instead of the rocker seen on the other examples
