Hi Neil
Both myself and Alex had some problems with insufficient incidence on the wing. It really needs the wing to be packed up at the LE about 1/8th of an inch. The rudder is also quite small so just make that a bit wider too. A bit more dihedral would not go amiss either. Apart from that the model flew straight off the board!!
Alex and I both used the Outerzone plan, I don't know if the original free plan had these issues. Oddly it is the only Boddo model I have had problems with.
Good luck anyway.
Glyn
Been in the loft!
Re: Been in the loft!
Thanks Glyn, I am still tempted to give the Apprentice a go, as it would be an ideal size for the local slopes and because of pure nostalgia. Plus I have at some point cut out more or less all the templates I need, and because Neil (iGull) does a set of laser cut parts for it.
