Mounting Kit for LemonRx DIY/Hack modules
Like B&Q for homebrew radios
As an alternative to double sided tape to fix the 2.4 module in place and to give the aerial a decent mounting on the aluminium Tx case, Tobe did a great job designing these, available in a soft yellow or rigid black plastic. The mounts allow the modules to click into the mounts which also provide a mechanical retainer to keep the aerial pigtails located in use. The mounts can be attached using M3 bolts/standoffs/self tappers conveniently within the Tx case.
https://www.ebay.co.uk/itm/134615248001
