Any radio hams out there? Say hello.
Re: Any radio hams out there? Say hello.
This is my rig next to the 40m transceiver I showed earlier, a 5 band QRP morse Mountaintopper CW transceiver with an output power of 4 Watts maximum. I now temporarily use a vertical in the house, about 3 m long on the first floor. Made another QSO with Croatia this morning, 1250 km. I designed the antenna tuner for this rig. As a tuner with a bridge for SWR measurement, it has always been a safe load for the transmitter. The SWR measurement works on the power of the transmitter, so does not require a separate power supply. Once the antenna is tuned in, switch off the SWR bridge and the antenna is directly coupled to the tuner. The fied strength meter I use for fine tuning. The morse key works with iambic B.
The set is powered from a 2500 mAh battery and serves for outdoor use with a wire antenna that I shoot into a tree with a catapult, for example or a 5 a 6 m vertical.
The field antenna and capapult
I first unwind about thirty meters and put it in eight shape in front of me. I use my catapult upside down, the handle on top and the fork on the bottom. I tie the carabiner to the end of the rope and shoot it over a branch of the tree. Then I first use a small pulley with a rope attached to the carabiner and pull it upwards and then lift the antenna. The pulley makes pulling down the antenna and pulley easier. I don't have to pull it back over the branch with the risk of it getting caught. First I lower the antenna and with the double rope of the pulley I pull the first rope out of the tree.
73 the PD7CW
73 the PD7CW
Ted Moss WA7VQR Peoria, Arizona. mostly used ham license for 52 MHz R/C. Tech + license (grandfathered).
Jay Mendoza here,
K5JJM
I'm in Mission Viejo California USA
K5JJM
Hi all
Quick hello from the land of Oz. Call sign is VK7GY - details on QRZ.com. HF only, but not very active and like many others I prefer CW (in my case, for the challenge). I've been a radio amateur since late 70s. I tend to stick with 80 and 40 metres.
Hope to get into it a bit more as I retired yesterday!
Gerry
Gerry
Hello Re ham radio,
I started out with good intentions ,made a pixie transmitter and contacted a society so I could get a ham license. So far so good !then I set my mind to learn Morse code .Thats when things started to go down hill,I had learned about fifteen letters .But it started to take over my mind I couldn’t get to sleep I just kept going over and over the dots and dashes until I had to give up .
Did anybody else suffer a similar situation to me and how did you get through the barrier ? Tony .
I was first licensed in 1973, upgraded to Amateur Extra in 1979. I still have some older Kraft and Ace RC equipment on 6 meters.
I operate CW on 20 and 40 meters most of the time, usually chasing DX.
73 de WBØVPS
Southwest Missouri, USA
73 de WBØVPS
N7IVS Extra
Was WN7LPA but didnt upgrade 1970(ish)
Here's an interesting software defined receiver, based around the very cheap Pi Pico, one of the OLED displays we often use, and a couple of other chips.
This is video 3 in the series, best watch them all and look at the documentation, if you're interested.
Just a reminder to UK hams that we should re-validate our licenses at least every five years:
https://rsgb.org/main/operating/licensi ... alidation/
There's no test or any awkward questions, its just to say "yep, I'm still here..."
I've missed the 5 years a couple of times and got away with it so I try to do it every year.
