Hi all.
Looking in the archive on singlechannel.co.uk, but can't find the sketch for the Digispark RDT encoder.
Can anyone point me in the right direction?
Many thanks
RDT sketch?
Re: RDT sketch?
Do you actually want a radio dethermalizer (RDT) or one that uses a timer, or both? What sort of output to actuate the dethermalizer do you want? I know some use a relay or relatively high current solid state switch to melt a bit of fuse wire, or burn through an elastic band.
If you only want it to work with the radio, you could most likely use a miniature servo directly connected to the receiver to 'pull the pin' - you can get servos four grams or less, so probably no more weight than the Digispark and its associated switch gubbins.
Re: RDT sketch?
Stew,
The timer sketch that Carl posted some time back may be of use - viewtopic.php?f=41&t=348&hilit=timer
While Carl developed it as a motor timer, substitute a servo for the ESC and...........
Food for thought
Food for thought
