Thanks lads
It means there is some packet loss, but that's ok, if it's a 'stable' 7hz that doesn't seem to vary much it could be busy channels at your location that aren't getting through, You could check by doing a pair of RF Nanos with a different 16 channels to your usual ones. It could be something resonant at a particular frequency that's 'absorbing' a channel. Also, is the measurement method accurate? Essentially servos need 50 updates per second and your set is receiving 140 so plenty of redundancy left!
A full NRF24L01 FHSS Single Channel outfit :-)
Re: A full NRF24L01 FHSS Single Channel outfit :-)
Possible to post a link to the nrf units purchase origin?
With so many clone units that simply do not have any range (still see many reports on this), it would be, I think , a good addition.
I did see a reference to "keywish"...so do they deal from one of the online suppliers?
Phil you were spot on with your thinking as to why I was only getting a 7Hz packet rate. After playing with a couple of Nano RFs I managed to get a steady 10Hz after changing the channel numbers. All loaded up in both the S/C and propo sets and rock steady,
Many thanks!
There is a Ali Express link to a Keywish NRF in Phil's lockdown project some where. I used it and ended up with some EBYTE shielded ones. They work very well.
John
Many thanks!
John
Looked and found reference but link is dead.
So back to original request I guess.
Edit: Tried searching for Keywish store with Aliexpress as a reference, all suggested ways to find the store came up a big fat zero.
Hi John, just to clarify, the transmitted packet rate is 200 per second, the rx LED flashes every 20 packets received - so your packet rate at a 7hz flash was 140 per sec (plenty!)
Its best to search on Ali Jeff as the links never last very long, its like Amazon, a marketplace for various sellers that come & go
Here is a 'current' Keywish RF-Nano but it will probably be gone in a couple of weeks:
https://www.aliexpress.com/item/1005002105253367.html
these look ok too, doesnt say Keywish so may have CSN & CE on different pins:
https://www.aliexpress.com/item/1005004921028246.html
The 'canned' transmit modules are like this: https://www.aliexpress.com/item/4000132850562.html
...then you just need some sort of 328P processor board, a Promini, Nano, DIY-More etc
For short range you can make a tx using another RF-Nano but you cant really fly with it (I tried, ask Shaun!)
I do actually have a few spare canned tx modules but we cant send international post yet following the ransomware attack on the Royal Mail
PS Order an extra RF-Nano, it makes Martin's band-scanner so easy to build!
viewtopic.php?f=42&t=1008
Thanks for the info....much appreciated.
I had been searching for "keywish" but can see now it may have been futile given the suppliers you mention here.
Cheers Jeff
Cheers Jeff
