Digiace Label
Post your images here
Digiace Label
If anybody needs to replace (or is missing) an early Digiace label I have used a photo of a good label and tidied it in Photoshop and saved as tiff files. If anybody needs it, I can save them as pdf, just pm me.
There are two files:
KO_Digiace_white.tif is intended to be printed on transparent/clear label material and then stuck onto aluminium or printed onto aluminium effect material, so the clear lets through the aluminium.
KO_Digiace_silverif.tif is if you are printing on white transfer material and have the silver parts of the label in a suitable "grey" to simulate aluminium.
KO_Digiace_white.tif (153.2 KiB) Viewed 10207 times
KO_Digiace_silverif.tif (153.99 KiB) Viewed 10207 times
Re: Digiace Label
Thanks Mike! will post a pic when I have printed one off and mounted on the Tx! ;)
Re: Digiace Label
Here are the prints from Mike's excellent artwork, printed on self adhesive inkjet labels ;)
Digiace decal
Digiace decal
Re: Digiace Label
And here is the clear one installed on a tx. next to an original
Re: Digiace Label
Which is the original and which is the one you printed? It's good if I'm not certain which is which! It certainly looks better than no label.
