Martin and Mike.
Thanks for the replies but nothing changes
I have reloaded the blink program several times with differing delays and that works fine.
The programmer file (ArduinoISP_Nano_D2.ino) also loads without a problem ( but only with ATmega328 old bootloader) and the reset line is wired into D2. I have now checked and rechecked the inconnect wiring about 4 x and with an independant checker.
However it still fails 100% of the time, with the same batch of errors listed above.
Its also rather frustrating that I have Windoze on 3 PCs, but the ArduinoIDE will only program on 1, the other 2 suffer from Port not found problems that none of the dozen or so help suggestions work for !! Grrrr.
I have yet to find my USBASP programming harness to try, but I have always found that patchy with a lot of whining about drivers.
Any other suggestions?
Thanks and rgds
Barry
Simple, reliable alternative to USBASP programmer - Arduino as ISP
Re: Simple, reliable alternative to USBASP programmer - Arduino as ISP
Aha, success, but not with the Arduino as ISP!
I found one of my USBasps, I had 2 lurking about. It works perfectly1
So I guess I'm in the 1% where Arduino as ISP fails. I'd still like a solution to get it working if possible though.
Rgds
Barry
Rgds
Barry
This whole Arduino thing is becoming nuts.
In my last post I said a USBasp programmer worked fine. It did, just once!! Then it has never worked since, It seems to be a port problem. I have spent some hours fooling about with zadig, drivers from the FTDI site and tried many of the fixes proclaimed to work on various websites and forums. With 2 different USBasp programmers and 2 different cables.
Loading the basic blink into the same Arduino works well, with varying blink rates to verify a new successful load. Then, loading the “Arduino as ISP” sketch (ArduinoISP_Nano_D2.ino) into the same Arduino seems to work, at least no errors are generated. And I can reload blink sketches back into it as well.
But then, trying to use it as a programmer is a constant fail. (the error report is below) I believe I have the settings correct, The selected programmer is “Arduino as ISP” and I use “Upload using programmer” I have checked the 6 interconnects (via JR and Futaba leads) several times, and the reset line is connected to D2.
I would love to be part of the 99% that experience success with the Arduino as ISP
Any more ideas on the fault and how to fix this?
Rgds, Barry
"Sketch uses 4354 bytes (14%) of program storage space. Maximum is 30720 bytes.
Global variables use 482 bytes (23%) of dynamic memory, leaving 1566 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x78
Failed programming: uploading error: exit status 1"
Rgds, Barry
Anybody got any ideas on this?
Barry
Barry
What happens when you try 'upload using programmer' when the target board isn't connected to the programming board? I think you should get a different error message (like 'target not responding') when the Arduino as ISP is talking to the ISP, but not connected to the target board.
Make sure that the Serial Terminal part of the Arduino IDE is closed when attempting an upload.
Do you have a different Arduino you could try to use as the programmer?
- Flynn
Following on from Martins post, the results Albert is getting is same as I can get if the uno hasn't been programmed with the 'arduinoasISP' sketch. Here, the Uno has the blink sketch installed and I am trying to upload the 7channelencoder sketch using upload by programmer with the programmer set as arduino as ISP -
The programmer is not responding because it has not been flashed into the Uno!
If the uno has been correctly programmed with the ArduinoasISP sketch and no 'target' device connected I get this -
This shows the programmer is working but cannot talk to the target device. If I then fit the target device (an ATTINY13 in this example) I get this -
So it looks to me Albert as you are not getting the ArduinoasISP firmware installed in your UNO. I suggest you remove all connections except the USB lead to your Uno, upload the blink sketch to your Uno and verify the 'L' LED on the uno is flashing, then select the ArduinoISP sketch from Files/Examples/11.ArduinoISP and upload that. The 'L' led should now be on all the time. If you now attempt to upload any sketch using 'Upload using programmer' you should get the invalid signature response -
Once at this stage you can connect your target device and it *should* work.
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:.....................ckages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
avrdude done. Thank you.
System wide configuration file is..........diy_attiny\hardware\avr\2023.4.19-gcc7.3/avrdude.conf"
Using Port : COM4
AVR Part : ATtiny13
Chip Erase delay : 4000 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 64 4 0 4000 4000 0xff 0xff
flash 65 6 32 0 yes 1024 32 32 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
System wide configuration file is .............es\diy_attiny\hardware\avr\2023.4.19-gcc7.3/avrdude.conf"
Using Port : COM4
AVR Part : ATtiny13
PAGEL : P00
BS2 : P00
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Device signature = 0x1e9007 (probably t13)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\g7ocm\AppData\Local\arduino\sketches\6386BECBF8172B613CCE089C3EA59973/ATTiny13.ino.hex"
avrdude: writing flash (502 bytes):
Writing | ################################################## | 100% 1.03s
avrdude: 502 bytes of flash written
avrdude: verifying flash memory against C:\Users\g7ocm\AppData\Local\arduino\sketches\6386BECBF8172B613CCE089C3EA59973/ATTiny13.ino.hex:
avrdude: load data flash data from input file C:\Users\g7ocm\AppData\Local\arduino\sketches\6386BECBF8172B613CCE089C3EA59973/ATTiny13.ino.hex:
avrdude: input file C:\Users\g7ocm\AppData\Local\arduino\sketches\6386BECBF8172B613CCE089C3EA59973/ATTiny13.ino.hex contains 502 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.42s
avrdude: verifying ...
avrdude: 502 bytes of flash verified
this check.
- Flynn
Albert?
