Ace Nautical Commander Docs
Posted: 01 Feb 2023, 17:08
by Grif
Any links to the TX construction, docs and schematics for the Nautical Commander system?
Re: Ace Nautical Commander Docs
Posted: 01 Feb 2023, 18:58
I think there was more than one model of the Nautical Commander. Mine has the Signetics NE5044 encoder chip which was widely used by many R/C manufacturers in the 1980s, such as DigiFleet and Kraft. The encoder board has a similar layout (but not identical) to my Ace Silver Series and the schematics are similar enough that you you should be able to work it all from this link:
https://vintagercfiles.com/Files/ACE/Silver%20Seven/
- Nautical Commander
- Ace_NC.jpg (41.47 KiB) Viewed 13736 times
- Silver Series
The left-hand part of the circuit boards are near identical, the right-hand part of the Silver Series is for servo reverse/throw which my Nautical Commander doesn't have.
The only Ace Commanders and Silver Series I have ever seen are all on 72MHz, I don't know if they did a 27MHz, 35MHz or 40MHz, so may not be suitable for use in Europe, but OK if you are based in the States.
Posted: 01 Feb 2023, 21:34
Mike_K wrote: 01 Feb 2023, 18:58
......The only Ace Commanders and Silver Series I have ever seen are all on 72MHz, I don't know if they did a 27MHz, 35MHz or 40MHz, so may not be suitable for use in Europe, but OK if you are based in the States.
They did a 27MHz version which I modified to 29MHz, the frequency band used in Australia at the time. Great radios!!
Posted: 01 Feb 2023, 22:07
by Grif
Thanks guys,, I think that gets us close enough...
