OS Pixie Receiver replica
Posted: 12 Apr 2018, 16:46
by RON
Hi Guys,
Just finished my OS Pixie Receiver replica.
Thanks very much to Frank for the .scad file. I tweaked it a little bit to accommodate my v8 frsky receiver and put the "Made in Yorkshire" text on it. Printed in white laser resin its come out superb. very smooth and the text nice a crisp.
Held together with a strip of gold mirror vinyl, very similar to the original I think.
Ok this was an expensive print but I think my lovely Pixie transmitter deserves a lovely receiver to match it.
Here's some photos of the project
Re: OS Pixie Receiver replica
Posted: 12 Apr 2018, 19:00
by stuart mackay
Posted: 12 Apr 2018, 19:59
by PaulJ
I love it!
And it's a great use for all those "other ends" of the servo leads that you cut off for the transmitter projects!
Posted: 12 Apr 2018, 20:52
by tiptipflyer
Looks great Ron, almost better than the original Pixie receiver.
Posted: 13 Apr 2018, 13:24
by _AL_
Superb as always.
Al
Posted: 14 Apr 2018, 00:26
Hi Ron
When I suggested you needed a Pixie case for your Rx, I was half joking. But now you've made one, it's a must have item for us Pixie converters/builders! What a lovely job you've made of it.
So the last bit of Pixie "bling" you need is the green centre loaded coil cover. I've ordered a small reel of green PLA that I think will match the original, so I'll print a few, then we can all have a green blob on top of our 2.4GHz aerials
I've done a little test in the workshop this evening to see if a FrSky antenna with the black cover removed, will transmit OK through the Pixie case, which it did with no loss of range (on a range check). Se we could put a dummy aerial on the Pixie with a green blob half way up and have the active part of the 2.4GHz antenna internal in the case at the top.
Over to you Ron!
PS I love the "Made in Yorkshire" text. I guess Neil will have "Made in Scotland" and I'll have "Made in Herts".
Posted: 14 Apr 2018, 09:05
by tiptipflyer
That was my thinking also. So I made up a drawing of something that looks like the center loaded coil, without ever having seen one in person. Here is what I made with my very limited knowledge in drawing with OpenSCAD. It consists of two halves glued together over the arial. I could not do it any better.
Any more accurate solution is highly appreciated.
- Spule.png (8.89 KiB) Viewed 17451 times
Posted: 14 Apr 2018, 17:35
by RON
Thanks Mike, sounds great. I’m tempted to make another Pixie but a special edition maybe in Red or something different. Also tempted to do it in laser resin for the ultimate finish.
