That was a very stable flier David, in the windy conditions. Very nice indeed.
I've tried avoiding the flea, but it keeps coming back like an itch I just need to scratch!
I am looking to build a couple, a larger one for biger fields 60"+ or thereabouts, and a smaller version, sub 40"
Flea
Re: Flea
This is Ian Redshaw's 1/2 scale flea; flies a treat. Has a Zenoah 62 petrol up front and a huge chunk of lead. Genuine colour scheme.
Have a look at it in flight here https://youtu.be/RVd_ekrUFoQ along with Tony's.
Re: Flea
Ian Redshaw's "Berty Bassett" Flea has appeared at the LMA's October exhibition at Gaydon. Impressive size, but, remembering it's only(!) half scale, it's still modest by modern standards at 130" or so w/s. The Wrisley 1/4 scale version is just 66", which sounds quite small until you see how much wing area that encompasses.
Mine flew quite adequately on a 4S 3500 MAh Lipo and a 40-series EMax motor. I moved it on to a mate a couple of years ago and this discussion has made me wish I hadn't.
BTW, that "slot" effect still manifested itself if you suddenly opened the throttle after cruising on low power - until the front wing got its act together, the nose would drop quite markedly! Worrying until you realised what was happening. Just had to hold your nerve.
That huge chunk of lead I can believe! Mine carries around a pound and a half and there was no way it would fly without it.
Re: Flea
That must be the Carden-Ford engine I imagine, same as used in the Chilton DW-1.
I have permission from the lady whose relative built the first DW-1, to build a full size one, and I have the plans, but (A) I'm about 4 stone too heavy (I'd have to take off with empty tanks) and (B) no workshop!
(or time and money for that matter). So My permission letter will be a framed keepsake until my lottery win comes off!
Some use a converted Reliant engine, (from the old Robin) and some have used flat fours, but that looks nasty...
I can only stand in the hanger at Old Warden and drool over the two examples there.
I always loved the Flea, ever since at the age of 8 I nicked all my mams clothes props and tried to build my own Flea using dads lawnmower engine. They were neither happy nor impressed with resulting pile of wet washing and butchered lawnmower...
Ah the innocence of youth!
Re: Flea
While reading this posts, I was up for another flying session with my flea. So this morning up we went. I had a wonderfull flight with the flea, taking off from the ground and even made some barrel-rolls without crashing. Great landing.
Frank- Wayne_H
Re: Flea
Said flea flighters will also need a unique "badge" to proudly identify to non-flea flighters their unique itch. The afore mentioned Phil has already demonstrated what that should be - viewtopic.php?f=61&t=865
Be loud & proud I say...........
