I flew the ATTiny tx this morning in my Buzz Bomb modified to use a 9g servo instead of the Ace magnetic actuator - great range & solid feel but alas the linearity has deteriorated to a point where the stick assembly is unusable . There is a dead spot & a significant "jump" in servo travel in one direction, not so bad in the other direction. Back to the drawing board
I have two D&R single axis sticks that I purchased from Ace years ago. If I can get my 3D printer working correctly, I'm thinking of trying to emulate them but modified to use a conventional pot. Added to the list......
New Digimac 1+1 revision 3, a few more bells & whistles
Re: New Digimac 1+1 revision 3, a few more bells & whistles
Old 27mhz model car radios are a good source of single-axis sticks...
Sanwa Dash, Acoms Techniplus, Futaba Attack, Hitec Ranger etc
I've just had some forced 'down time' while recovering from some minor surgery. Rather then be bored or waste away watching the idiot box, I put the time to good use by making another 1+1 Tx .
For this version, I turned the case on it's side, my thinking being 2-fold:
1. I can comfortably hold the Tx in my left hand with my left thumb over the throttle button while launching, then hold the Tx with both hands while flying --> pseudo Mode 2 - right thumb steers while left thumb controls the throttle.
2. its a little different The case is a bland neutral coloured cheap plastic job off 'the bay'. Since it has a shallow recess on the front, I inserted red stick-on auto vinyl in the recess after painting the case black. This colour combination reminds me of a 7ch Micron Tx I have tucked away in a box in storage. I used a D&R stick with a separate D&R trim pot. The encoder is Phil's ATtiny 1+1 Mk2 Rather than use an internal Frsky module as is my normal practice, this Tx has a plug in Multi-Module (from Banggood), operating a FlySky Rx. All in all, a 'recovery' day well spent
Looks fantastic Wayne, I like the inlaid vinyl idea. Where are the 'D&R' sticks from?
(no Yorkshiremen to keep you in check over there?)
You realise a genuine Flysky RM002 module is only £14?Wagga_Wayne wrote: ↑14 Jul 2018, 03:51Rather than use an internal Frsky module as is my normal practice, this Tx has a plug in Multi-Module (from Banggood), operating a FlySky Rx.
Thanks Phil
Since Flysky run two software versions, I have more series B RX's than series A, so I bought a 003 module for them. The multi-module doesn't 'talk' series B, but it does talk FlySky series A + Frsky + Walkera to service my eclectic collection of early 2.4G RX's.
Thanks for the code, the Tiny version works really well & the boards are cheap - simplze
The sticks and trims came from Ace. I bought a lot of Tx hardware, pcb's & servo mechanics from them back in the late 70's & early 80's. They were always great to deal with.
Yes, I'm a long way from Yorkshire but there is some ancestry to keep me in check
- iflylilplanes
The throttle button, the momentary buttons I have, have 3 pins, one side opens when pressed, the other side closed when pressed.
Which way please?
Dave
Which way please?
Dave
Dave
Dave
A long overdue conversion using phil's excellent digispark encoder
Nice!
The Macgregor 1+1 is one of my favourite sets - lovely relaxing way to fly rudder-only
Mine is a regular flyer in the Vic Speed Poppet... totally dependable, around 30-40 watts which is plenty. Love it
The wrong way wont damage anything but will hold the encoder in stick-calibration mode.
PS For the 1+1 there is also a throttle channel converter module for boats, which sits between the Rx and a reversing ESC,
and converts the "off/mid/fast/mid" sequence to "off/forward/off/reverse"
Specifically it changes the throttle channel timing from "1000/1500/2000/1500" to "1500/2000/1500/1000"
Otherwise, on a reversing ESC, the standard throttle starts up in full reverse!
If the set is permanently in a boat this could of course be done in the 1+1 sketch, but the module makes it more versatile.
Dave, really sorry I missed this, so 3 years late, its the push-to-make you need - which you probably know already!iflylilplanes wrote: ↑23 Nov 2021, 08:55 The throttle button, the momentary buttons I have, have 3 pins, one side opens when pressed, the other side closed when pressed.
Which way please?
Dave
- iflylilplanes
No problem, Phil, I worked it out, the Testors Simpulse1 works great and is going into it's first model, Jack Headley's "Tadpole" glider.
Thanks anyway.
Thanks anyway.
Dave
Dave
