Receiver Identifications and info
Stewart
Post by Stewart » 28 May 2019, 09:38
First I have a Mc Gregor R60 superhet sc receiver, I need info as to what crystals fit, ie: does it have the early unusual i.f. frequency or regular later standard?
Secondly, I have an unidentified superregen receiver 27mhz , As the relay is samped OS Japan , im asumeing its an early OS unit.
also anyone know what voltages these use?
Re: Receiver Identifications and info
Post by RON » 28 May 2019, 15:44
Not sure about the first one Stewart but the Blue aluminium one is almost certainly 470khz IF frequency. 470khz below tx crystal.
If you would like to contribute a small amount toward the upkeep of this valuable forum then please click the Donations link at the top of the page, just below the mode zero logo. All donations are kept anonymous. Thankyou
Stewart
Post by Stewart » 28 May 2019, 17:51
Thanks Ron, I suspected the McGregor had a 470 if , you wouldn't know were I might obtain a set of crystals?
Post by Wayne_H » 28 May 2019, 22:47
Stewart wrote:
28 May 2019, 09:38
Hi Stewart,
Here is wiring diagram for my RS-1 superhet Rx which most likely has the same relay - max 6v/1A
