Plan at the moment is to have a Scan command that will use just one of the modules to scan the band and display what it thinks are the two strongest frequencies present. Those become the default 'A' and 'B' frequencies when S is pressed again to stop scanning, or a different command is entered.
Then there will be A and B commands that allow you to enter the 'A' and 'B' frequencies manually, if you want to adjust them.
Finally a Transmit command that toggles between transmitting just on 'A', or just on 'B' or both, or neither.
I'll make a YouTube video demonstrating it once it's working. I have a Lemon transmitter module, but currently it's not connected up to anything. I guess I need to get that working too, to properly demonstrate the functions of my 'DSM2 jammer'
