The board is one of his smaller GTB encoder boards. I have followed Mike's manual which is very good. Only issue I have found is to make sure the Joystick gain pot RV1 is fully anticlockwise or you will only get half of the stick movement.
A few pictures of the conversion as follows:
I have reused the existing wiring for the switches and the meter. Looks a lot neater and I only had to crimp some servo connectors on them. I replaced the wiring on the sticks as they were not long enough and also they move a bit when the trims are used so I was not happy using the old wires. It is very tight in the case I had trouble fitting the switches in the top. I had to put the spacers on the outside. Got the meter on the case working but had to add a 10k resistor inline with it. I used the "meter adjust" pot to fine tune it.
Still waiting for a a lemon diy tx module to turn up and a 2s lipo balance socket to I can get the 5-pin DIN plug wired up. I plan to run the 3 wires for balance plug on the 2s lipo and binding to the 5 pin DIN as Mike has done on his. Don't really need to do it as the case is really easy to open.
So far I am happy with the conversion and Mike has done an excellent job. I'll update when I have finished it and tested it out.
Rob.
