This version is a 72Mhz AM set, probably from the late 80's or early 90's. It is very clean & in great condition - no corrosion, wires still very flexible, etc. I'll need to change it over to Mode 2 when I do the gigification.
I'm intending to use a Tobe encoder board running Phil's FHSS code, and make a matching Rx to fit inside the Cannon Rx case. The conversion is on temporary hold while some ongoing medical issues are being sorted since our return from NZ last month. Having waited since the early 70's to get a Cannon radio, another month or so is not a hardship.
I've downloaded plans for Ken Willard's Cannon Ball, which is the obvious destination for this radio. Oh to be able to get to Ponte
