New mystery model
Anything with a propeller
Re: New mystery model
Here is another example for a very rare model using the same technique for a dummy motor, a Webra Winner 2.5ccm diesel engine.
The model is a Hegi 60 U-control combat racer, which I converted to R/C using the elevator as elevons. The only changes I did :
I increased the fin area by about 50% and mounted it straight and cut of the longer wing half so they are equally long now.
It is really a great flyer, tighter loops are simply not possible.
Looks great Frank. The reason I asked is I saw an article in FMT (I believe) many years ago where a genuine OS 60 was modded and had an out runner fixed where the backplate originally was, piston , liner etc removed and a new shaft and front bearing to replace the crankshaft. Looked great but must have been heavy.
Lovely job Frank, as usual ;)
I have a Robbe ASK16 about 2/3 done, but it's been in storage for far too long :cry: while travelling around doing project work. Wings are framed up, including retracts & spoilers & tailfeathers made & covered. I've filled in the engine bay cutout, always intending it to be e-powered.
I think the Robbe 16 is a little larger than the Graupner 14, but they sure do look very similar, more so than the full-size originals.
The robbe ASK16 is a great model, larger than the ASK14, and looks great in the air especially when equipped with retracts.
I never had one and it is hard to get one, even in Germany.
I still have another very old kit of an ASK14, even older than the Graupner one. I hope to build that one too in the future.
That one is larger, about the size of the robbe ASK16.
Hi guys,
it´s been a while since my last post. But I was busy all the time.
Here are my latest updates.
I converted my 50 years old Graupner Floride to electric power and changed the look to the 1968 catalog finish.
A dummy Taifun Bison replica was used to make it look more realistic.
Also the Graupner Amateur got a new power unit, now electric also.
Here a dummy OS MAX 10 with the old style muffler was used.
Very nice Frank, as always 👌
Lovely that frank,
I love the dummy OS10, looks so real.
Great job as always.
Love the Floride Frank.. It's a baby Caravelle one of my favourite early aerobatic planes.
Hi guys,
I have a new model, well it is not really new but at least over 50, maybe even 60 years old. I got it on a swap meet.
The wing still has the original tissue covering with the original decals on it. I just added the green color to it.
The horizontal fin had to be recovered in tissue and I modified the rudder by increasing its area by about 30%.
To get it in the air without any problems I added a small motor in the front and a radio for rudder and elevator.
Most of you will recognize, that it is a Graupner Passat, a free flight glider from around 1960.
Wingspan is 189cm, length 120cm, weight 600g including a 2s 1300 lipo.
It flies like a dream, of course only in light winds.
Cracking, classic model Frank. Pity you won't be at Ponte this year with some of your fleet.
X
