Place your Goblin build photos etc, here
I'll be starting mine within the next few Days, it would be nice to see other goblin builds here too
The Goblin Builds thread
GeeW
Re: The Goblin Builds thread
Hoping to start mine next week, plans printed and new No11 blade fitted to scalpel.
(note to self- put plasters on shopping list)
Ron, will you be making a pylon power pod?
Hi Gordon.
Not sure about a pod yet. I’ll see how she goes first.
Just started the build. I’ve built the center section of the wing. Seems to be going together quite nicely.
I recommend a small length of thin piano wire around 80mm in length adding to the trailing edge in the center section to stop the rubber bands cutting into it. After sanding the T/E it’s quite thin at the back.
Its been awfully quiet here of late. Does that mean nobody other than Ron is building a Goblin?
My kit turned up tother day (thanks Neil
), but I thought that I'd give those of you in the mother country a head start
That's my excuse, what about the rest of you then???
GeeW
Cheeky bugger....
Afraid to say some of that real life stuff has rather messed up the next couple of weeks as far as building goes <sigh>
OTOH I was gifted a Skyleader Tx so I now know what my next 2.4 conversion is going to be. So not all bad.
Gordon
Gordon
So, has anyone made any Goblin progress, 'cause it's still awfully quiet .............Wagga_Wayne wrote: 05 Sep 2018, 13:33 Its been awfully quiet here of late. Does that mean nobody other than Ron is building a Goblin?![]()
- Carl
I have one to build, and it's moved up the queue since finishing the Starstream.
"Thank you for waiting. You are number 17 in the queue"
STILL LEARNING
STILL LEARNING
see my post on the 2019 Theme - hopefully it will spur some activity here
, especially since you northern hemisphere lads should be moving into your building season
and lots of Igull kits were mailed out...........
