Merco 61Mkiv Carb
List it here.
jackdaw
Merco 61Mkiv Carb
Post by jackdaw »
WANTED
A bit of a long shot, but thought I'd ask.
Has any one got in their spares/junk box a complete twin needle carb for a Merco 61 MkIV; choke bore 7.25mm and spigot diameter 11.8mm.
Thanks.
Re: Merco 61Mkiv Carb
Jackdaw,
I confess to not being very clued up on the different Mks of Merco 61 but there seem to be at least two different twin needle carbs. I don't know if it has the carb you are looking for but this appeared on ebay today at quite a low "Buy it now" price.......
https://www.ebay.co.uk/itm/Merco-61-Mod ... SwwlJdqGow
jackdaw
Post by jackdaw »
Saw that Paul. But, the throttle barrel location screw is sheared off and the whole engine looks to be a 'bitsa'. It has the later separate cooling jacket and liner(earlier models had a one piece steel unit) and the earlier thinner crankshaft. Which probably means an earlier crankcase with the smaller carb.
MJF
Post by MJF »
Hello from Canada jackdaw
Some Merco stuff was listed today on RC Canada
https://www.rccanada.ca/rccforum/showth ... p?t=578403
You might have to register to bid which cost nothing and is not a big deal.
Prices shown are in Canadian $$ which are not worth much!!
Hope the link works.
Mike F
