ACE RC Foam Wings
Re: ACE RC Foam Wings
Looks like Neil may have some new products in the pipeline. So just how do you 're name' it? Changing the title has no effect. I'm given no other options when downloading. I'm just stupid
Could this be a basis for next year's Ponty mass build?Igull wrote: 01 Dec 2019, 22:17 Once I can get an accurate scan, I'll attempt to do something simple.
Neil
Hi Jack,
Download the file: 'right click' -> 'save target as' ->
Put it somewhere you will find it again easily.
Navigate your way to that place where you saved it, 'right click' on the file, 'Rename', remove the .pdf bit and put a period (full stop??) between ME109 and dxf.
It's as simple as that!
I am not aware of any on-line or simple .dxf viewers but you can still download Draftsight for the month of December before it is no longer free.
I've attached a real .pdf just to confuse everybody.
- Me109.pdf
- No dreaded file extension woes!
- (78.7 KiB) Downloaded 259 times
Well that's what I did before. Did it again and I get the same result, 'corrupted .pdf file'
- Igull
That's pretty much perfect Phil - thanks a lot for that - confirms what I thought in that all the "plans" online that I've looked at are actually wrong - generally a tad thicker - probably some recogniseable section from eppler or somesuch and bears no relationship to Owen Kampen's shoe insert at allPhil_G wrote: 01 Dec 2019, 23:02 Any good Neil? This is with the root & tip pressed firmly against the scanner bed. Cant get them absolutely flat as the root has a locating tab and the tip is rounded.
Root measures 137mm and tip 103mm. Half-span is 453mm. The root has a short parallel section where it fits the fuselage, about 30mm, ie the TE tapers not from the geometrical root but from 30mm out.
Folks just want to pick their own section and use that - which is fine, but this is a true scale aircraft and all the rivets need to line up
Good note about the tapered version root start too - and that the regular version has that rounded over trailing edge and NOT square (folks do trim that off to add ailerons of course).
As they are to be laser cut balsa versions and not moulded foam, I'll probably stick to the AceRC/Doc Mathews school of wing building - strip balsa - and even more strip balsa (or usually spruce , no sheeting except for the roots - and no dihedral braces either
It's me that's making them, so I make the rules of course
Thanks again for that.
Neil
- Igull
Hi Bellibelli wrote: 02 Dec 2019, 07:48 Hello Neil,
I went down this road a few years ago, for fun I digitized all the Ace kits with an eye towards making reproductions. I did it for fun and ended up never building any....
Thanks for that, I checked your section against the original, and that too seems to be a bit thicker
There seems to be a plethora of models designed for this wing, so there shouldn't be any excuse for you not to get on and build some
Neil
- Igull
It's actually not a PDF, it's a DXF with a PDF extension, just rip off the PDF extension part and make it *.DXF - you'll be able to open it in something that'll read DXF. There are a couple of extraneous bits for the tailplane off to the right of the drawing that will confuse youjackdaw wrote: 02 Dec 2019, 17:45 Well that's what I did before. Did it again and I get the same result, 'corrupted .pdf file'
Neil
- Igull
I can see the $$$$$$'s already - I'll need to take early retirement to make them - oops, I'm already retired and spend my days making millions on MZ Goblin kits
BTW, I saw someone on ebay flogging cheap used gall bladders, that wasn't one of yours I hope
Neil
No, I've kept it to use as a pressure tank in my next c/l team racer .
- Igull
Not lost that sense of humour thankfullyShaun wrote: 02 Dec 2019, 22:23 No, I've kept it to use as a pressure tank in my next c/l team racer .![]()
Glad you're still with us Shaun otherwise we wouldn't have someone to slag off
What's a c/l team racer BTW ? Must be something from the last century I presume - never heard of it - maybe Phil's got one in the same box as his Ace RC Foam wing
Neil
