Conversion woes? [Fixed: inverted ppm!]
Re: Encoder woes?
Flynn that sketch is years and years out of date, read line 16 for example! :D :D :D
// Follow the story on the single-channel forum http://singlechannellersreunited.co.uk/phpbb3/viewtopic.php?f=8&t=109
Not that theres anything wrong with it, it just that in later versions it developed quite a lot since then.
In your case, what you've done to invert ppm is correct :)
Current version is here
and the document: here
I'd encourage use of the current version, makes it easier to support if we're on the same version.
Flynn wrote: 05 May 2024, 08:46 What a great piece if software by the way...
Hardly... it was ok at the time - but whilst its not in Mikes league, the new one is much better! :)
Flynn
Re: Encoder woes?
Post by Flynn »
Gotcha. But if it ain't broke why fix it. :-)
Now it's working I will just leave it as-is but if I have a problem in the future I will be sure to update it before asking for assistance. ;)
Presumably Mike offers his PCB's for sale? Not that I am in the market at the mo.
The DIY-More strong boards from Mikes link are on offer at the moment...83 available @ $5.63 + del. Wallet feeling restless Phil?
Re: Encoder woes?
I've enough for the occasional animatronics board requests I get thanks Flynn, I dont want to buy a huge stock of boards as they are only occasional, and my R/C encoder requests have dried up now there are better alternatives available. BTW your gps pcbs arrived, very neat, thank you! I need to order some bits... :)
