The first item is an old valve rx with relay. The only discerning mark is "E.C.C - England". Anybody able to identify it or tell us anything about it? Next is a servo/actuator by MK Japan. Not sure if this is a proportional servo or a S/C servo. The 2 sets of 3 wire leads are interesting(?). Are they for daisy chaining such servos together or are they for a separate battery for the servo motor, or?? Any ideas? There are 2 actuators that use a mighty midget motor. One actuator is clearly home made, the other looks more commercial. Both have wiper plates & wipers suggesting, to me at least, that these are S/C actuators. Again, Any ideas? Over to you guys
Seeking info on some old bits 'n pieces
I was recently loaned some old R/C bits 'n pieces to have a look at & photograph before having to return them (bugger
Re: Seeking info on some old bits 'n pieces
Hi Wayne
That's a lot of vintage R/C gear there! I'll work my way though your photo's, but the first one is easy, ECC were one of the early UK set manufacturers and their receivers were very popular, both for price and reliability. Shaun has a complete boxed set of ECC:
viewtopic.php?p=10200#p10200
Don't know much about the MK servo, their other 6 wire servos were for S/C with contacts for throttle servo, so I assume the same. And the other actuators look familiar, I expect Shaun and others will recognise them without me looking through back copies of RCM&E magazines.
ECC was probably the first reliable commercially available RC set in the UK. There were a couple of versions of the RX and the Tx was one of the very first hand held sets.
I've not seen the red MK actuator before but MK actuators from memory were marketed by RipMax in the UK and renamed RMK.
They had a number that used the mighty midget motor .I would guess the red anodised one is a MK manufactured unit.
But wait, there's more
Thanks for the info chaps, much appreciated.
