PWM to SBUS
List all your sketches here
PWM to SBUS
This sketch reads up to 18 channels of PWM, and outputs the results as an (inverted) SBUS signal. You could easily modify the sketch to just output test SBUS signals (steady, ramping, etc.) rather than read the values from PWM inputs. Might be useful if you want to make an SBUS 'servo checker'.
PWM2SBUS.zip
(3.82 KiB) Downloaded 316 times
