Flysky/Eurgle/Imax transmitter module wanted
List it here.
PJG
Post by PJG »
Hello, I am seeking a FLYSKY FS-TM001 transmitter module, which fits the 9x modular transmitters (and my retro conversions!)
This has the non-hopping DSSS protocol. It also came badged as Eurgle and Imax.
Please search your stashes. Many thanks, John
PJG
Re: Flysky/Eurgle/Imax transmitter module wanted
Post by PJG »
Phil_G wrote: 06 Aug 2022, 16:58 We have threads on the RM002 and RM003 in the modules section if they are of any help :)
Thanks for the rapid response, Phil.
I have been FlySkying since 2009 and have a lot of the early kit, which has never caused a moment's problem. Also hopping kit with TM002 and
RM002 modules.
FYI, herewith a FlySky compatibility chart https://rc.305.cz/storage/FlySky_Tx_Rx_ ... _table.pdf:
I guess you will be getting down with the kids at 'Spoons in Biggleswade by now. Bon weekend ;)
John
Hi John
I'm fairly certain that the 4-in-1 multiprotocol modules, such as the iRanger and Jumper support all the Flysky protocols including the original one. And convenient for you, the original FlySky protocol is selected with the switch in position 1, "bank 1" in ppm mode.
https://github.com/pascallanger/DIY-Mul ... FLYSKY---1
They're not the most convenient module to use in conversions as they are JR module format, but the case can be removed and some of the cheaper ones come without a case.
https://www.aliexpress.com/item/3272909 ... 1659823163
The dead-on-arrival reliability of the iRanger is terrible, so I'd avoid that one if possible, but if aniRanger works for a few minutes, then they're as reliable as any other module.
Cheers Mike
PJG
Post by PJG »
Many thanks, Mike.
In truth, I was looking for a solution more suited to a short-armed Yorkshireman with deep pockets! :)
