A new adventure in Indoor.
Control Line Flying. First tests. Radio controlled throttle.
https://youtu.be/z-0EmQ3s9Jw
Sunday 16 July 2023 at Shearwater, Dartmouth, Nova Scotia, Canada
Indoor Control Line Flying
Small-RCer
Nothing like the smell of Nitro in the morning.
Re: Indoor Control Line Flying
Around 1970 our club the SSA held indoor meetings at a Uni building in Sheffield, we used to fly electric indoor C/L back then, all-sheet profile models with a slot-car motors and a small 12v lead-acid in a shoulder bag... a bit like RTP but you were the pylon, and had elevator control
I quite fancy a go at C/L again, the Carrier Deck class looks interesting, slow as you can, fast as you can, then a spot landing...
Would have to be electric though, dont fancy all the oily mess that goes with IC...
GarydNB
I'll build one if you fly it Phil....
Gary
Gary
Small-RCer
Another better video of that indoor control line flying. Not sure if the same flight but it is the same person flying. Throttle Tx is in his left hand.
https://vimeo.com/890643928?&login=true#_=_
People yakking in the background are other flyers socializing rather than observing an amazing flight.
- Flynn
....then there is the alternative. 12V car battery at the 'Ballards' pole, two wires carrying the current to the model fitted with a 1 gram 4 channel Rx with an esc and a 2 gram micro servo on elevator... saves getting dizzy.
