GG Throttle emulator
Waggly tails
F2B
Post by F2B »
My PH-SAM (Dutch equivalent of SAM35) buddy Raymond lately converted his Fleet to 2,4.
As I understood, there was a three position toggle switch that made the Rand actuator go all the way round either way for throttle control.
Meanwhile the rud. & ele. controls were flapping round neutral.
Raymond connected the switch to propo Ch 3 for a 1000-1500-2000 channel pulse.
What was needed: a propo to propo servo board that made teh servo slowly going open or close, depending on the input being 1000 or 2000.
Or better >1700 : open and < 1300 : close. between these values, servo stays put.
I nicked Phil's AtTiny elevon mixer for the in and output lay out.
Next I added some stuff for making it work, and it did. ;)
Took me a while :roll: understanding why the output switched off when the input went blank, as I tried to sneak in some sort of failsave.
Of course, when there is no interrupt, the output won't be running either... :oops:
Never mind, failsave is up to the 2,4 receiver then.... :mrgreen:
AtTiny85_switch_slow.ino
(1.72 KiB) Downloaded 97 times
Testing with a pot instead of a switch, you can clearly see the 1300-1700 neutral 'window':
Edit, I've moved the MP4 file to YouTube - Mike_K
F2B
GG Throttle emulator correction
Post by F2B »
I added the wrong .ino file, now it is the right one..... :oops:
Video: I tried the link, but it's not there (but some sort of table saw) :roll:
Re: GG Throttle emulator
Woops, I linked the last mp4 video that was posted on mode-zero, not yours. I think it's working now
Nicely done Bruno
I thought we'd done a 1/1.5/2ms to progressive converter but I cant find it now so maybe not! :D
Or maybe I'm thinking of the reeds-to-fwd/reverse thing for Lester?
I remember we did do a version of the re-coder for genuine Rands, which did the throttle rotations...
Its great to see theres still interest in GG :D
In an old mag I found an advert for a 'jumping ghost' actuator, any ideas what that was?
It looked like a mighty midget with a few bits added... :D
