Conversion of Skyleader Sticks from Mode 1 to Mode 2
Vintage Pilot
Post by Vintage Pilot »
Does anyone know if it is easy/difficult/possible to convert Skyleader transmitter sticks (Clubman black sticks rather than the silver ones) from throttle on right stick to throttle on left stick? Is it straightforward to change over the ratchet and spring(s)? Or is this something set at factory that can't easily be changed?
Julian
Re: Conversion of Skyleader Sticks from Mode 1 to Mode 2
Hi Julian,
Skyleader sticks are so easy to change from mode 1 to mode 2 or vice versa that the biggest job is unscrewing the back off the transmitter and putting it back. Carefully remove the spring off the elevator and move it to the new elevator stick "scissor" centring levers, unscrew the ratchet clamp off the throttle onto the new throttle and the job is done. It shouldn't take more than a minute or two.
Vintage Pilot
Thanks Mike
