Babcock Transmitter BCT-2& BCR-3 new In box
MJF
Post by MJF »
A couple of years ago I saw an advert to "come and pickup a box of old transmitters or they go to landfill". In the photo I saw the corner of a Controlaire 10Ch reeds type transmitter which I really wanted. Off I went to get the assorted transmitters and found a wealth of neat old stuff in the plastic tote box. There was a catch however, I could not keep the tote box I had to bring my own!!!!
Among them this unused still in the original box Babcock BCT-2 transmitter and an in the box Babcock BCR-3 receiver also unused and as well as an original manual.
Boxes are in great condition considering their age
it.
The rubber grommet around the "Radiation" bulb has deteriorated.
BCR-3 receiver
BCR-3 receiver
As typical with these very old radios no antennae was included. You were expected to use a 3 foot length of about 3/32" piano wire to plug into the transmitter socket.
From reading the manual I saw a date of 5/15/53 on the schematic drawings (probably drawn once and used for the entire productions run!)
Babcock BCT-2 BCR-3 manual.pdf
The manual scan ended up being almost 5 Mb so here is the cover shot only
(175.6 KiB) Downloaded 13 times
I thought it was far too good for landfill! It is still in the box on a shelf probably waiting for the next owner to do the same with it.
Attached is a report from Air Trials magazine October 1953 covering the system
Babcock BCT-2 TX & BCR-3 RX - AT Oct53.pdf
(446.93 KiB) Downloaded 15 times
