Cardinal
Anything with a propeller
jef
Cardinal
Post by jef »
Some pics of the Cardinal I've built the last 2 weeks
ImageDSCN5477
ImageDSCN5478
ImageDSCN5480
Rudder control "old school" 8-)
Cheers Jef
Re: Cardinal
Looks great! Has it flown yet? Mine needed very little power when it had its DC Merlin engine and I found it was best to fit the prop backwards and also run the motor with low compression to give a persistent misfire.
Re: Cardinal
Jef,
In case you haven't flown your Cardinal yet - looking at the video & assuming(?) :o that you have set it up with the CofG as per plan, then you have way too much rudder control. Mine flies with about a quarter of that throw and still has heaps of control.
Of course, if you have the CG much further forward, then its less of a problem. I'd still halve the throw for the first flights.
Hope you get as much fun from yours as I have from mine.
